RSLogix 5000 User Defined Tag Error
sanger
Nov 2005
Toronto
172
I'm working on an RSLogix 5000 v15 applications and when opening one of the User-Defined data types I receive the error:
"This data type was created using Import command and it contains bit overlays. Data types with bit overlays cannot be modified."
I've never seen this warning before. If I wanted to modify this data type would I need to export it, modify it offline and import it again?
Yes - export, modify, import.
Though I hate the restriction. Bit overlays give you the frteedom to treat a tag section two different ways. Very useful.
Do a forum search on bit overlays. They have been discussed and there are some examples.
Usually when I use a bit overlay but I know I'm also going to have other items in the UDT, I first create a UDT that contains only the DINT with the overlay. Then I create a new UDT and include the first UDT with the overlay in it. Since its less likely that I will be modifying the first, I still keep the ability to modify the second.
hello every one as i am new to this forum i want to know detial of udt in rslogix 5000 does all tags in udt get in my program? if i have to write...
15,987
Hi, I created my own tag (6 reals and 2 dints). I tried to send it via msg to another PLC, and error 16#0013 "configuration data size too...
18,480
Is there a command that you can use against a UDT that will fill it with zeros? Of course the UDT has dint, bool and strings... EX: FLL...
11,306
Hi, I would like to know how to delete user defined data types...No tag are related to those data types... thanks Martin.
19,503
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
156
