RSLogix 5000 User Defined Tag Error
sanger
Nov 2005
Toronto
172
I'm working on an RSLogix 5000 v15 applications and when opening one of the User-Defined data types I receive the error:
"This data type was created using Import command and it contains bit overlays. Data types with bit overlays cannot be modified."
I've never seen this warning before. If I wanted to modify this data type would I need to export it, modify it offline and import it again?
Yes - export, modify, import.
Though I hate the restriction. Bit overlays give you the frteedom to treat a tag section two different ways. Very useful.
Do a forum search on bit overlays. They have been discussed and there are some examples.
Usually when I use a bit overlay but I know I'm also going to have other items in the UDT, I first create a UDT that contains only the DINT with the overlay. Then I create a new UDT and include the first UDT with the overlay in it. Since its less likely that I will be modifying the first, I still keep the ability to modify the second.
hello every one as i am new to this forum i want to know detial of udt in rslogix 5000 does all tags in udt get in my program? if i have to write...
15,992
Hi, I created my own tag (6 reals and 2 dints). I tried to send it via msg to another PLC, and error 16#0013 "configuration data size too...
18,520
Is there a command that you can use against a UDT that will fill it with zeros? Of course the UDT has dint, bool and strings... EX: FLL...
11,337
Hi, I would like to know how to delete user defined data types...No tag are related to those data types... thanks Martin.
19,526
68
