RSlogix activation question.
mjt
Jun 2007
Shotgun Shack
Hi! This question may have been addressed so if it has, please pont me in the right direction!
The company I work for has a legal copy of RSLogix500 with one activation on a floppy. I would like to be able to do programming at home and save it to disk to take to work or print on paper. I am allowed to take the installation CD home and install into my computer but I can't run it without the activation. Is there any way to run without it, like in a demo mode?
Thanks!
Thanks, Mickey. Unfortunately, the company will not allow me to take the disk home. Can I personally buy another activation? Don't know if the company will....
Just noticed that the PDF was discussing RSLinx. I don't need RSLinx at home to run RSLogix 500 do I? I wouldn't be downloading to a PLC from home.
There is a way to do a demo of the software. well not actually a demo because it unlocks it as fully functional. The one catch is it is used by sales people to advertise the product so it does not have a key that you can install. You must use the floppy and I beleive it has some sort or time limitation on it. If you would like a copy of this sent me your email and i will email it to you. It is not a crack or hack or a key. I obtained it from our distributor and you need the floppy in order to run the software. So in essense it is kind of a demo. I think it has a run time of 2 hours per run or something like that. I have never used it at home for that long of time so I can not say 100%but I know it works.
Thanks!
Hi! You mean I would have to have the activation disk at home oto run it? I don't think I would be allowed to take it home. They are kind of funny like that...
How if you do some illegally tricks. Just copy that license then you can take it home.
As long as its not use for commercial.
Thanks!
The demo mode I know of was, and I think still is available is, RSLogix 500 Starter 10 point Micro Logix 1000 English
I think its available as a down load or contact your rep for a CD
This has most of the functionallity of Logix 500 but just throttles the I/O available
Using bits instead of I/O allows more capability.
If you are just wanting a self training aid the above achieves that goal.
If your employer really wants you to work from home he would buy you an activation
rPraveenkum said:
Good solution
Install the activation in Pendrive take it with you
(y) (y) (y) (y)
OK, really don't mean to hijack this thread, but I have to ask, is it possible to install activations to a thumb drive, memory stick, flash drive (or whatever you want to call it)?
I have a couple of machines that I have to transport activations to/from occasionally and doing it with a memory stick would save my nerves (floppies scare me, they're so unreliable).
rockwell recommends it
http://rockwellautomation.custhelp.com/cgi-bin/rockwellautomation.cfg/php/enduser/std_adp.php?p_faqid=31319&p_created=1110862800&p_sid=*yxLuBEi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQ6MSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NSw1JnBfcHJvZHM9MCZwX2NhdHM9MCZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9RVZtb3Zldw**&p_li=&p_topview=1
The original post conveyed the idea to me that his company did not wish for the floppy with the activation to leave the plant. (The floppy may or may not contain the actual activation depending on if it was transferred, but could be used to boot his home computer, but that is a different issue.)
What I find strange is that now it's okay to take a flash drive with the activation home? Managers just don't have a clue.
For the record, I agree with Ken Moore. Put the activation on the laptop. Take the laptop home. Leave the other stuff at work. And if nobody likes it because you can't do extra work at home, I guess you can't do extra work at home, now can you?
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
16
1,001
Hello friends; Good day. I have windows 10 64 bit OS and install a Oracle virtual box with windows xp SP3 X86. I installed RSLogix 5000 and RSlink...
5,146
So I had this problem last night, and could not find a fix anywhere on the internet.. Called Tech Support this morning such an easy fix I figured...
8,605
Good day! I would like to ask how to reset my activation since i changed the whole computer where the previous license was installed. But when...
6,592
Yesterday i bought notebook hp compaq 6910p (its a old but great machine ) which used WinXp a Pcmcia slot for my 1784-pcmk/b card. I need install...
33,455
