Rslogix Emulator issue
Bunnon
Aug 2017
North Carolina
Good afternoon!
I am having an issue with creating a controller in the emulator. I have set up RSLinx and can see the server, the Linx "ethernet" connection and any of the I/O modules I create but when I go to create the controller it appears on the emulator graphic but has a big red X over it and says controller not responding. It also does not appear in the drop down menu under the virtual back plane in RSlinx.
Things I have done:
1. Reassign RSlinx server from slot 0 to slot 6 so I could put the controller in zero. No change other than the position of the server in RSLinx and on the emulator graphic
2. I have created I/O modules in every slot to make sure they would work and appear in both the emulator and RSlinx. I/O and server will appear and work in any slot that I can put them in. Controller fails in the same manner regardless of slot or configuration.
I am at a loss as to why I can't get the controller in an emulator to work. I have done this a dozen times before and this has me stumped. Any help would be greatly appreciated.
Respectfully,
Chad
Hello i have Rslogix 5000 installed on win 10 and VM win 7 installed on this laptop. The Emulator installed on the VM7. Rslinx on win 10 does not...
516
Good Evening Gentlemen, we have a FT View SE client running in windows 7 system, now I want to update that system with windows 10. I did the...
2,724
Hi, can someone help me how to setup communication between rslogix5000 emulator and Ftview Me. Based on manual rslinx enterprise is required in...
2,128
Hi All, I am working on a project which uses compactlogix PLC and Citect SCADA. I don't have physical PLC at the moment. Need to test tag...
5,596
dear friends, please I need any document or video which explain all the necessary steps(configuration) to do a project with rslogix 5000...
1,391
