RSLogix500 copying data file values off-line
keithb
Aug 2002
Basingstoke, UK
53
Hi all.
Suffering from brain fade here. I've just done a search and replace of approx. 400 addresses (4 complete data files) in RSLogix500 V7. The symbols and descriptions have been moved to the new addresses/data files, but how can I now copy the values stored in the the original data files into the new data files? The original data files have a lot of setpoint data that I do not want to have to re-enter by hand.
Note* I'm working off-line here as I don't currently have access to the PLC.
I just checked. You can right click on the old file and copy, then paste it to the new file location. It will move the data, but the descritions and symbols are not affected.
I'm trying to copy a String file from one program (RSLogix 7.20) to another. I get an error: "An attempt was made to access an unnamed file past its end". It works with other type data files; am I doing something wrong, or can't it be done?
Cant use a move command, so how does one move as string is rslogix 500. I cant seem to find and string related commands for copying.. I can...
12,552
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
542
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
1,993
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
685
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
1,005
