RSLogix500 - How to Clear Data File?
Grendizer
Apr 2012
Toronto
88
Hey all,
I have:
30 Float Data File each containing 256 elements. I want to clear the values of all the 30 Data Files, how can I accomplish this?
This is in RSLogix500
Thanks,
I would make another Float file of 256 elements of 0 then just COP it to the files you want to clear. You can do this one rung at a time or if you want to get fancier, use indexed address.
Thanks for the reply.
1766-L32BXBA
MicroLogix 1400, 12 digital fast 24V dc inputs, 8 digital 24V dc inputs, 6 relay outputs, 3 fast 24V dc outputs, 3 normal 24V dc outputs, 4 Analog (12 bits) inputs, 2 Analog (12 bits) outputs, 24V dc power
Nice! That would work.
One question thou, if I create indexed address, how do I cycle through all of them? Use a counter or something?
Another way is to use the FLL command with a source of 0 (constant).
In either case you can only copy or fill file up to 128 "words" at a time. Since a float is two "words" this means four instructions per file in 64 element blocks.
If the files are consecutive, try something like my example. This will zero out all 256 elements in 30 consecutive files taking place over 30 PLC scans. If you need them all done in one scan, then a LBL and conditional JMP could be added in:
Thanks for your solution, I will look into it now..
Thank you @OkiePC
Your solution is beautiful. I took your concept and modified it a bit. Also used JUMP-LBL (even thou I hate doing this).
You're awesome!
Hey All, I have a table like the following example: B21:0 0 0 0 0 0 1 0 0 0 1 0 0 0 0 B21:1 0 0 0 0 0 1 0 0 0 0 0 0 0 0 How can I clear the...
2,859
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
543
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
1,993
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
685
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
1,005
