RSLOGIX500 pointer???? How do?
Marcosbelgo
Jun 2015
Belo Horizonte
34
Hi friends,
I need to build this logic in rslogix500 and I'm having difficulties. Can someone help me?
N7:X/Y - Where Y is the product number (product1,product2......) and contain the size of each product.
N7:W - Is the product number.
I want that the PRESET of my counter (CTU0.PRESET) be loaded with the N7:X/Y where Y is equal N7:W
I'm not sure what X and W are supposed to be, I'm assuming some constants that you will fill in later? If they are also variables, this won't work.
MOV
Source: N7:X/[N7:W]
Destination: CX:X.PRE
Also worth mentioning, N7:W cannot have a value greater than 15 when this instruction runs or else it will fault the controller due to the INT data size limit.
MOV
Source: N7:X/[N7:W]
thank you friend, it's just that ........ very well remembered about the limit of N7: W, but this easy to solve. Hug.
268
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
552
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
2,021
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
699
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
1,017
