RSLogix500 Starter Installing Software
berrabbit5849
Nov 2011
Daingerfield,Texas
117
I am getting the starter version of RSLogix500. Can someone give me a guide as to what and how I need to do to install this software. The info I get from the internet talks about FACTORY TALK AUTOMATION. What do I install first ? Factory Talk, RS Links or RSLOgix ? This software will only be used on 1 laptop. And we don't care who uses it. The PDF instructions I got from the AB site is a little confusing.
[email protected]
Install RSLogix500.
You will only need RSLinx if you have a SLC that you want to connect to your computer.
You will only need Factory Talk if you plan to develop graphical operator programs to control a process with a PLC.
Of course, that is the AB Way.
I don't think it matters which you install first.
After you install RSLogix, and be fore you run it, you have to run Factory Talk Activation Manager
There should be a Red folder with the CD.
On the paper inside should be the Serial Number and Product Key that it asks for.
Like Lancie says you need RSlinx in order to communicate with your PLC.
Rslogix 500 is the program you use to write your Ladder Code
Factory Talk Activation Manager is really just for copy protection, and you will probably just use it the one time.
Rslinx is the communication software that you only need when you are Uploading/Downloading, or communicating with the actual PLC
Good Luck!
If my laptop hard drive fails and I lose everything can I reload the software on the new hard drive and then connect to Factory Talk to get it activated again ? I may retire in 3 years and might wont to put the software on another laptop.
You can. In my experience you may have to spend a little time on the phone with Rockwell support, but its not too horrible.
I can do OFF line edits but not ON-LINE edits? Correct ? Can I monitor a running PLC processor with the starter version ? If I use an INPUT...
3,793
allen bradley used to have a freely downloadable version of rslogix on their website that was intended for students, that is fully-featured but...
2,116
hey gang need a little assit here, I have a micrologix1000 series D and I downloaded the free rslogix500 for micrologix 10 pt from Rockwell. All...
5,043
Hi all, I read on the archives that i can download a free version of RSLogix500 as starter kit. For that i should look somewhere on ab site...
13,276
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
542
