RSLogix500 "unexpected file format"
bbear
Dec 2006
ohio
63
I am trying to open a file (.RSS) in RSLogix500 application offline and am getting "unexpected file format".
I can open other files with the same RSLogix500 application without problems and I can take the same file (.RSS) to another PC that has RSLogix500 application and open the without problems.
Any ideas?
Probably a version conflict. Files created with a newer version of the software sometimes will not work with older version software. It also might be a bad or corrupted "save". Try to find an earlier .bak file of the same name to see if that could be the problem.
version
Thanks.
The Version that is working is 5.20.00; the Version that has the problem is 2.57.00. I tryed to open the file from two different saved dates and had the same problem.
Definatly a version problem. I had a similar problem today. The file was saved in V7.10 and i had v7.00. I could open the file but when i tried to go online if said it was corupt. Most of the time you will find that if you can't open it or if you try to go online and can't but LINX sees it, then it's a version problem.
285
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
556
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
2,030
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
706
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
1,026
