RSLogix500 V8.4 CPR9 misplaced menu
Lovell
Feb 2013
Saskatchewan, Canada
120
Hi Guys,
Is there any way to restore menu locations in RSLogix500? I dragged the Tabbed Instruction Bar too far up and now I cannot grab the title bar to bring it down again. I have tried Alt+ SpaceBar but it moves the program window not the undocked Tabbed Instruction Bar. I have also tried different screen resolutions but it keeps the Tabbed Instruction Bar at the top. Any suggestions?
Thanks,
Lovell
try Alt and the Minus Sign key ...
or ... if that doesn't work ...
shut down RSLogix5000 ... then hold both the Shift and the Control keys WHILE you restart the software ... that's "supposed" to put everything back to "out of the box" conditions ... note that any options that you've saved will probably be blown away too ...
Hi Guys,
Thanks,
Lovell
With Rs500 closed.
Run Regedit, Browse to Computer\HKEY_CURRENT_USER\Software\Rockwell Software\
Find the key structure named Rs500, right click, export somewhere safe.
Then delete the key structure Rs500.
169
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
543
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
2,002
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
689
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
1,009
