RSLogix5000: Assigning Slots
smittylsr4
Jul 2013
Louisiana
Good evening! Doing some programming for a Compactlogix PLC and have what seems to be a silly question about assigning slot numbers. For example the CPU sits in slot 0, I have 3 input modules a power supply and two output modules. If I place the 3 input modules after the CPU (slots 1-3) and the power supply after the input modules does the power supply count as slot 4 or should the output module placed after the power supply be assigned slot 4?
Appreciation in advanced.
It's actually a great question.
CompactLogix power supplies don't communicate with the controller over the data bus, so they don't have a Slot number.
Your system will be:
Slot 0 CompactLogix CPU
Slot 1 Input Module
Slot 2 Input Module
Slot 3 Input Module
Power Supply
Slot 4 Output Module
Slot 5 Output Module
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
150
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
448
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,132
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
885
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,962
