RSLogix5000 FGEN operation
NetNathan
Nov 2011
Corona, CA
2,199
I want to linearize 13 points.
The output is to be linearized to a temperature range (0-2400 in 200 degree increments)
Where do I enter X and Y values? I do not see the ability to turn on the extra X and Y points.
I assume I do not need XY2Size only XY1Size? I have set it for 13, where do I enter the 13 X1 and Y1 values??
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
145
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
443
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,131
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
881
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,954
