RSlogix5000 function blocks question
sashac75
Dec 2011
Chicago
Hello everyone. My first tread. I am not a big specialist with PLC, but I have some experience, a little.
For our new project we have two 1336T Force drives with ControlNet adapters and two motors. Say simple, first motor feed the paper using the pool roll with defined speed, second one running rotating knifes to cut the paper right size. Speed command for the first, master motor, comes from another part of this big machine. Speed Command for rotating knife is directly proportional to both, master motor external reference, and ratio set point (size of the sheet).The bigger ratio for knife, the longer cut supposed to be(knife is running slower). So my final ratio will be always less than 1, if I understand wright. I think, I can use feedback encoder from master motor for knife reference and some ratio to get this done, and function blocks Pi and SCRV in RSLogix 5000. From HMI, I think, I can change the ratio for different size of paper. I made function block diagram, but nothing come out from PI output, plus I am not sure, if I configure the function blocks wright. Master motor base speed 1710RPM. Knife base speed 2500 RPM. Feedback encoders are 2048 PPR. For the drives data type is INT. I have 1756-rm006-em-p manual, but some parameters I don’t understand.
So ,if you guys help me, it would be great.
Thank you.
Just downloaded an existing app to this Controller and I can see instrument inputs changing in the tag list when I go online, but the clock is not...
4,899
Hi, I have just created my own add on instructions and imported them into a project but am now having trouble editing the new sheets. I can view...
2,914
Hello I'm trying to use function blocks to scale engineering units to W.C. reading. but I don't see the option to create the function block is...
1,067
I have not used function blocks much in Studio 5000. Could someone tell me the advantages compared to the dis-advantages.
1,424
I'm modifying my first function block program in RSLogix (I've only done ladder and ST on the AB PLCs before). The existing program looks like a...
1,795
