RSLogix5000 is Cancelling Download
Thor Hammer
Jan 2014
Santa Cruz, CA
36
PLC: Compact Logix 1769-L33ER
Ver: 32.02
Before the weekend I was able to communicate and download to the PLC without issue. The panel view plus as well.
Back after 4 days away and all that happened during that time was I changed my laptops static IP to a different address to communicate with a different platform.
I set my static IP on the laptop to the same as before (first 3 octets match the PLC and PV) upon my return. No X's or yellow ? marks in RSWho. I can ping the PLC from the cmd prompt and no errors. I can download to the PV and no errors.
When I try to go online with the PLC it first asks me to download the offline program as I've made some updates. It starts then after about 2 seconds popup screen appears that states "cancelling download"
Really stuck on this one. Any insight greatly appreciated!
You may want to double check the firmware revision on the file you are trying to download and make sure it's 32 also. Perhaps you grabbed an old file on an older version? From my memory, I've seen this issue when the plc firmware mismatches with the logix file revision.
Solution found. I, for whatever reason (lack of experience with this platform is my excuse) did not verify the program and controller. Once the warnings and errors were addressed all is ok.
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
134
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
439
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,128
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
876
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,951
