RsLogix5000 Produced/consumed
bulletin blues
Mar 2003
out there
223
So I set up a produced tag, and set the maximum consumers to 4.
I only have two PLC's on the network that will consume the tag.
Will this be a problem? How so? Just curious.
No problem. The data only gets multicast once on to the network.
I think the "number of consumers" value is used behind the scenes in the configuration of multicast group sizes, so with a small system you won't have to worry about it.
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
151
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
450
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,132
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
886
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,962
