TIP: you can find that same flowchart in the COMPACT-Logix manual too - but with just the name changed from "CONTROL-Logix" to "COMPACT-Logix" ... personally, I think that's just a "Copy-Paste" error ...
specifically, I haven't found any COMPACT-Logix systems (so far) that allow their input modules to be set up with COS (Change Of State) ... with that in mind, I'm not sure how the published COMPACT-Logix flow chart could possibly be correct ...
I've got quite a bit of work to do before next Monday at 8:00 AM - but if I can come up with some spare time, I'll try to put together some experiments to demonstrate how this stuff really works "under-the-hood" ... NOTE: I "THINK" that there's going to be a breakpoint between some older versions of RSLogix and the newer versions of RSLogix where the COMPACT-Logix rules are going to change ... this is going to take some time and work - because you can't always trust the books ...
(and a special thanks to daba) ...
