RSLogix5000 to SLC500 Messaging
Aug 2014
Earth
32
Can anyone tell me what would cause a CIP Data Table Read or Write message from 5000 to 500 to act this way? The message EN bit comes on and stays on...we never get the DN or ERR bit. EN just stays on. o_O
If the Message can't make a connection for about 30 seconds, it will error out and set the .ER bit.
Generally if you see the "EN bit stays on" symptom, you have too many MSG instructions running and filling up the available backplane buffers, or your logic is re-triggering the message automatically whenever it completes with a .ER or .DN bit.
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
129
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
435
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,127
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
874
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,948
