RSLogix5000 v16 - Unavailable Instructions within Add-Ons
tvey
Mar 2005
Halifax, NS
99
The help file for RSLogix 5000 v16 mentions several instructions that cannot be used within a custom Add-On:
Code:
JSR	Jump to Subroutine
               SBR	Subroutine
               RET	Return
               JXR	Jump to External Routine
               FOR	For (For/Next Loop)
               BRK	Break
               SFR	SFC Reset
               SFP	SFC Pause
               IOT	Immediate Output
               EVENT	Event Task Trigger
That being said, I created a test Add-On to convert Gray code to Binary using a structured text 'For' loop. It seems to work (using the emulator):
Code:
Binary.15 := Gray.15;
            for i:=14 to 0 by -1 do
            	Binary.[i] := Binary.[i+1] XOR Gray.[i];
            end_for;
So why does this work? I don't have a chassis handy at the moment so I'm unable to test on an actual processor.
I have a couple of Add-Ons in mind that could make good use of the occasional For-loop. I'm a bit leery of proceeding unless I can be sure of consistent operation.
Attached is an exported copy of the test Add-On (remove the .txt extension to import).
-Trevor
In ladder, the FOR instruction has to call a separate routine. It doesn't loop within a routine (like on a PLC5). You can still loop using JMP and LBL instructions.
From the list, it appears that the add-on's must be completely self-contained - i.e. no code execution outside of the add-on.
Hi, Anybody have link to download RSlogix5000V16 as I can not find it anywhere Regards Sandeep
1,417
I have a project a customer supplied an old version 5555 CPU (1756-L55) that I flashed to version 16.22 (the highest it would support) Using...
2,327
Hi, I have inherited an Allen Bradley project which was built using RSLogix5000 V17. My work PC has V16 installed so I can not open the...
4,535
Hello to all.. I need to convert a program that has been written in V16 of RSlogix5000 to Version 15 of RSlogix 5000. How would I go...
3,754
I don't want to polute other threads where people were asking this question: RSlogix5000 v16+: how to open local PDF manuals in a separate window...
3,104
