RSLogix5000 V20 slow?
TConnolly
Apr 2005
Salt Lake City
6,152
Ever since I upgraded RSLogix5000 to V20 it has been really slow to load (well over a minute to start the program), and really slow to open files. The start page is ridiculously sluggish, with the panel taking up to ten seconds to slowly roll back to the left window frame. Once I get the PLC program open everything seems to be normal speed.
Has anyone else notice it? Is this normal behavior?
I've noticed something similar when changing from different versions or if I'm running two instances, one of them v20 and the other something older but not exactly as you describe. Are you running v20.01 ?
I have same problem with this version 20, how to make this things work faster, i7 with 10G RAM cant help this software.. huh!!..
Hi All, i have rslogix5000 v19 licence, how can i upgrade to V20, is it required fee to upgrade. thanks in advance
1,160
Greetings, I just installed the rslogix 5000 v20.01 and I’m on the grace period. I wanted to try and use the programming functions like ladder...
17
7,658
I have a machine that I cannot seem to upload the program from. It kept throwing a fatal error saying that there was an unspecified communications...
4,222
Hi, So I have a piece of code that's identical on 2 machines. Both L62's running on RSLogix 5000 V20.01. Check var1 with var2, if NEQ then do...
2,030
How can I convert an RSLogix5000 v19 program to a V20 program, i dont have a V19.0 firmware, is it possible? if yes how? hoping for your response.
2,111
