RSLogix5000 with 3rd party servo motor
coa
Jun 2004
96
I uploaded program from Control Logix with RSLogix5000 V17. This PLC control servo motor from Parker with Ultra3000 with sercos network to PLC. I need to make servo tunning to adjust position and velocity loop but the program informed motion database does not contain data for Motor Catalog Number. I knew this problem due to servo monor not from Rockwell.
I can find Parker motor specification but how can I update motor database to RSLogix5000 then I can make servo tunning.
in Logix V19, you can select to enter custom motor nameplate data. In conjunction, you'll also have to run the commutation test - not that I've done that before :)
ttichy, could you tell me where to put custom motor data in RSLogix5000 V19
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
130
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
437
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,127
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
874
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,949
