Rslogix5000
Txslim73
Mar 2012
Texas
If i create a tag in logix how does my analog output card know which channel it is for? My loop is sending the 4-20 but nothing out my card! Can someone help please. I am use to programming rs500, so this is new to me.
You have to Alias it to the actual Analog Output Point Address.
Stu....
Ok that makes sense! Im waiting to take the 5000 class, but this will help. I couldnt find that info in the pdf files. Thank you!!!!!
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
160
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
459
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,133
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
892
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,967
