RSLogix5k - Map Output cards to memory
sparkie
Nov 2014
KS
1,148
So I am writing my first RSL5k program and I don't really have any guidance or direction on this one, so I have been ferverently reading. What is a good practice to map my physical inputs and outputs to an array.
These are discrete 120V Inputs and 120V outputs and I'm using a ControlLogix PAC processor. The reason I want to map the outputs to an array is so that I can program more closely as I would for an SLC500 which I'm pretty familiar with.
What is a good practice for doing this? Should I make a separate array for each card or put them all into a single array?
Thanks for the help guys.
Hi
I create an array for each card and I use a cop instruction to map from the card
I would also look in to Utd's and AOI's also as you would not have used these in slc
Are you using any servos?
Donnchadh
We are re-doing a conveyor system at our plant. There are 7 motors that will be ran by VFD's. I'm using control relays to turn on the FWD on the VFD (We don't have ethernet comms cards for them). I'll also have 3 start/stop stations, a scanner to scan product codes and a kicker to kick mis-scans off the line.
It is a pretty simple system all-in-all, so I'm grateful this is the first project they gave me. After some battles with the software I am ready to start programming.
I am basically taking what was a system with a rack and controlnet rack and cutting out the controlnet and utilizing an old cabinet and controller setup for these conveyors, as the system they controlled is no longer there. There really isn't much I need to do besides the field controls for the conveyor.
Hello PLCs.Net! I am trying to use RSLogix5k via windows command line. I would like there to be a script which automatically opens a project...
1,247
Hi, I recently installed a powerflex 700 drive in rslogix5k i/o tree. I am communicating thru a 20commE. I have no communication issues or faults...
1,592
Hello all, I have a csv file produced from rslogix that periodically logs the current state of analog inputs and alarm bool conditions and stores...
1,405
I've heard someone saying I should put as many programs/routines in the continuous task. I also heard others saying use as little continuous task...
18
6,458
Gents, I've a CompactLogix L35E V19 and a Telemecanique XUW vision sensor. There is an EDS file from the XUW, and I used the EDS hardware wizard...
1,575
