RSVeiw Studio connections problem
Saint AAI
Oct 2007
Ollerton
22
Hi, I've recently been given the task of programming a few PanelView plus screens and have never done anything like this before. I've been messing with the software and have got my head round most of it, but i'm having problems with the comms side of things. Most of the PLC's where I work are Omrons so i'm using KEPServer Enterprise as well as RSLinx Enterprise, but i'm not really sure what i'm doing and can't find any help. When in RSVeiw Studio I double click the communication setup and it starts the wizard, but when I click "Create new configuration" I just get an error message saying "Failed to copy the default template". Is there something i'm doing wrong or does it sound like a problem with the installation of the software?? Any help or links to some help will be much appriciated as I haven't a clue what i'm doing. Thanks, Shane.
Well I've been messing around somemore and I've changed my IP address and it now works?? Dont know why. I had a static IP before and I still have, but just changed it??
Edit.
Ignore the above, I loaded up a project that had already been done and the communications setup worked, so I opened a new application with what I wanted it to be called, then found the folder and copied the info out of the existing application apart from the .med file (if that makes sense, similar to getting a .mer file to work on RSVeiw Studio). Then opened up my new application and it works?? Still havent figured out how to get to the tags though, messing with one of our A&B plc's for the time being till I get used to it all. I can browse the network, but cant get to the tags, anyone help?
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
445
Morning, we are changing how we control an HMI by having our users sign into iFix which then sends a tag to the HMI. Looking at a specific DINT...
74
Hi guys I have a question for you experience people. I have a tben l4 8IOL module set up on a machine from the oem , And want to add a iolink...
43
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
97
