Hi all,
I m new in Scada and i want to connect s7 300 plc and rsview32. i tried to use kepserv opc but it work for com port MPI adabpter but i have usb port mpi adapter how can i connect s7300 with rsview232 using usb MPI adapter
You can do that with Ethernet but not with MPI unfortunately. If you have a an ethernet module on your S&, you can use this opc server. It's very easy to use as it auto detect the PLCs and auto configure them.
