On this screen shot, your EVMOVE software is not showing ANY key codes on Drive A (Under the "Installs" heading, there must be at least a "1", or more).
In order to MOVE a key code, you must first have one on the drive that EVMOVE is looking at. Do you have a key code on an existing hard drive? If so, change the "Move From" to Drive X, where X is the drive where your software currently is installed. Once you move the key code from this location, the copy of the program there will no longer run except in Demo mode.
EDIT: Warning, if you are unfamilar with the software, you can accidently move the key code to a disk and be unaware of the move. Then you will not know where it is or how to locate it. This could result in disabling of your software.
