RsView 4.0 historical trends
manasi
May 2007
maharashtra
123
Hi All,
Can anybody guide me for configuring historical trends of analog data?
I am using RsView version 4.0 and Micrologix 1200 Plc.
Regards,
Manasi
manasi said:
Hi All,
Regards,
Manasi
Are you using RSView ? 32 or ME or SE
In all the above, to Read Historical trends you need to set up a Data Logging Model to store the values in real time, so that they are able to be read as historical data at a later time.
Without a data logging model you are resticted to reading a trend pretty much in real time where data gets held in a limited buffer normally only whilst the display is active or still in cache.
There are lots of people who can help in this forum so if this does not help please ask a more specific question to get more responses
Once you build the data log model don't forget to add a line into the startup macro to START the data logging automatically.
When you program the models in Studio you can start the logging manually via a command line but if the system ever gets rebooted it wont re-start automatically without the macro.
One other thing is to make sure windows .net framework 2.0 is NOT installed otherwise the data logging wont function.
hi,
Thanks!!!
i am using RsView Machine Edition version 4.0. I have already added the required points in data logging models. but i am unable to see the historical data on panel View+
How can i see the hostorical data on panel view and how can i take its back up?
Regrads,
Manasi
When you create a trend, you can select the data log by, from the Pens page, selecting "Tags from Data Log Model" (or something similar; I don't have ME open right now).
thanks!
Actually i haved tried that before...anyway i will try oncemore...
Manasi
Is there a way to make the pens on a historical trend indirect tags so that you can associate any I/O point rather than predefined tags to one...
10,776
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
314
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
260
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
814
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
798
