Julian Osborn
Hi all
Having problems with communications to RSView32. It all started last week when I had an error on the SLC and had to reset it, it looked fine..... had the 500 ladder running and code is working fine.... turned on the SCADA Machine running RSview32 and all the tags on the screen associated with the SLC were blank in the usual no coms way... ok i thought lets start the code and see if coms are fine, even purchased a cheep XP machine on the new, installed linx, and new RSlogix500, all working fine on this machine now i have a full list in the Lynx comms panel but RSview still does not want to play? checked all the node and the channel setup yep all looks good. even tels me in the Lynx STATUS for the SLC505 that it is in remote run. Look on the old machine and in the Lynx status it says Faulted? have rebooted the SCADA Machine and still has a problem with comms.
at the bottom of the RSview in the new machine status bar it says " Channel 2 error - (IP ADDRESS) "The communications driver has not been
configured"
if the processor or network had any fault then I would not be able to see the Ladder part of the plc, this works telling me that there is no problems with comms.
configured"
