sparky64
I want to collect some data from an S7 - 400 using RSView32, I'm using KEPware.KEPServerEnterprise.V4, on my office PC, and have set Kepware up, so i can see the information i want when i launch OPC Quick client, because i can see the values i want in Kepware this means that the kepware is communicating with the PLC ok.
I've tried to configure a node in rsview, using the following settings:
DATA SOURCE - OPC SERVER
NAME - SIEMENS
SERVER NAME - KEPware.KEPServerEnterprise.V4
TYPE - LOCAL
ACCESS PATH - ?????????????? I don't know what this should be, i've entered the channel name and device name - Channel1.IgnitorLine
This is all accepted ok, but when i create a tag and monitor the tag, the state is ERROR.
Appologies if i haven't supplied enough info.
Any help appreciated thanks
Sparky
NAME - SIEMENS
TYPE - LOCAL
Sparky
