RSview & Kepware tag databases
jeffy
Jun 2010
Auckland
35
I am using RSView32 works and Kepware as the OPC.
I find it frustrating that whenever i need to add new IO to the scada system, I have to edit tag databases for BOTH the RSview & Kepware separately.
Is there any way that they be both managed together? Let me know if I've missed something. Thank you.
Hello Jeffy,
You should only need to add tags in the RSView32 database. Instead of using a Kepware tag name as part of the item path (static address), use the actual register address of the hardware device (Dynamic address).
Here is an example of a static reference to a kepware item...
Channel1.Device1.MyKepwareTag
Here is an example of a dynamic reference to a kepware item. (in this case modbus)...
Channel1.Device1.40001
Valid register addresses for the Kepware drivers can be found in the driver help files provided by Kepware.
Hope this helps!
Ethan Olsen
Product Manager
Kepware Technologies
You may be finding the situation where RSView does not update the Cache file for both RSView and/or KEP.
Do you know how to delete the Tag cache file for your project in in RSView
so that they get rebuilt from scratch to include the new tags
Thanks Ethan & Gil for your responses. I followed Ethans suggestion and it has answered my query! Thanks fellas!
Hi Working with some project guys who have replaced a controllogix processor previously using RSLogix 5000 V11 for a controllogix 5588E using...
4,024
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
297
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
251
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
810
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
794
