RSView via Serial Cable
afoley
Jul 2002
Collinsville, VA
68
I am having a really hard time with what I thought would be really easy...(Does that sound familiar to anyone?).
I simply want to connect RSView to a SLC 5/04 via the RS232 port. I configured the driver in RSLinx, RSWho shows me the Processor, I set up the Channel in RSVIew, then the Node, again RSWho shows the processor, but at runtime RSView says the Driver is not configured....what am I missing?
FYI
I don't know what version of RSLInx you have but RSLinx Lite won't run RSView.
Bob
Thanks a lot, Bob O.
I hadn't thought of that and it may be the problem, I have RSLinx Pro on my laptop, but I may have Lite on the PC I am trying this on...I'll check this out later. Meanwhile any other ideas on what I should check, if that should not be the case.
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
800
Dear Experts We are using 4 Rsview stations communicating with redundant contrologix having rev 13 on a LAN. We need help in following 4...
3,742
I'm trying to connect my Siemens PLC to my AB PanelView 600+. I have the AB PLC conected without a problem. I'm not sure how I would go about...
14,013
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
327
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
270
