RSView32 memory tag question
i_love_plc
Mar 2007
windsor
How can I have an memory tag created in RSView to reference to a VB varable.
ie.
I create a vb varable call "totalminutes"
I also created a device tag call "pCount" referencing to the PLC say c5:0.acc
Now, how can I have the memory tag call "Rate" to have the value of pCount/totalminute.
Your VB app will need to periodically 'poke' the value of "totalminutes" to a tag in RSView. Use the derived tag editor to calculate "rate" as "pcount" divided by the 'poked' tag.
Use this syntax:
gTagDb.GetTag("pCount") = totalminutes
If you want to read from the 32 use it this way.
Dim i
i = gTagDb.GetTag("pCount")
Hi guys, I'm working on a RSView32 project, some of the tags i'm using is memory tag & type is 'String'. These are like product name, I've a...
5,234
Does anyone know of a way to transfer tags and their values from RSView32 to a USB memory stick, build a folder for these tags and timestamp it...
2,137
How much memory that RSView32 software has? 70M? I confuse with the PC memory, which is at 512MB, 1GB, etc...
1,967
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
377
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,914
