I'm new to this ecellent forum, and a little dated in my PLC knowledge.
Those familiar with the AB Panelviews know that when you place a momentary button, you can set the duration of this momentary pulse when the button is pressed. I typically set it at 0.2 sec which insured adequate time for the latch signal from the motor starter to latch my run signal in the PLC code.
I have a situation in RSView32 where I do not have this duration setting, and the operators are pressing and releasing the button before the PLC code picks up a run signal (via Intellicenters and devicenet) to latch it in. I hate to modify all of these rungs to use latches, unlatches, and timers to solve the problem. Is there a simpler way folks have used?
thanks in advance..
thanks in advance..
