rsview32 password button
stu
Aug 2005
England
786
Hi guys
i have change a couple of screens on a existing project and i would like one of the screens to have a password , in pvp i know you can passord protected button , so when you press the button a password screen pops up, could the same be done on rsview32 and if so how thanks
As in the PVP you can create a login screen and require the user to login. Your users can be assigned access codes. Assign security to the display that prevents them from accessing it unless they login first.
OG
edit....
You could also configure a button to check if the current user has a specific security code. If they do, then access the display. If they do not, pop up a login window. Look at the "CurrentUserHasCode" function in the expression editor.
Hello, I have an old RSView32 app, when the project file was copied from an old HMI to the new HMI, the VB now has compiler errors in a hidden...
3,965
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
397
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,926
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
609
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,452
