Version 6.30.17 very old
Project has not used vba scripting prior to this problem
Took the 6.30.17 project and put it into a 7.20 version
running on Windows 2000 to develop changes on with the
understanding that the changes would be hand coded into
the 6.30.17 version. Used 7.20 just to prove out the scripts
and changes.
The OS for the 6.30.17 was upgraded to XP SPK2 sometime
in the past two years.
I am amazed that 6.30.17 even ran on XP
So the script work great on the 7.20 under Windows 2000
The script created inside the MS Form runs great on the 6.30.17.
But the calling script that loads the MS Form as simple as it is in the MyProject tree, will not run.
It does not fault, it just does not run.
So I am lost as to why
It would seem that if the script is run from in the display
environment, verses the MS Form environment fails to
function properly.
and changes.
function properly.
