RX3i FGEN function?
NetNathan
Nov 2011
Corona, CA
2,199
Does the RX3i have a function generator to linearize a non linear input?
Hopefully it supports about 12 break points...
The equation will change.
I am adding correction factors to a thermocouple.....So every time a new thermocouple is changed, they need to edit the correction factors.
As you have an RX3i, you can write your own custom Function Block if they don't have what you need. You can use any of the available programming languages including 'C' to write these.
Also, did you look into the PPS Functions that are now available to all with PME Professional?
How do I load the PPS functions?
Do they exist in 8.50?
And yes..... it also exists in LD! It is called "Function" (same as PPS library).
Now just to figure how it works...hard to see how to write to x and y inputs.
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
403
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
302
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
117
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
989
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
406
