Rx3i GBC controller IC694BEM331 Dual Bus Working
If you mean can you have two or more in a system, yes.
If you mean can you use a BSM on two of them, I don't know but if yes, it would need to be "turned on" in the hardware configuration, maybe with an HHM?
I have a Redundant configuration. One primary rack and one secondary rack, I also have two bem in each rack. I have connected the 1st bem of primary and secondary rack to Bus A of my GBI card and the 2nd bem of primary and secondary rack to Bus B of my GBI card.
But the BEM can only be configured for 'none' or 'external'. It does not provided option for 'Redundant controller and Dual Bus'.
How can I make it to work in Dual Bus configuration i.e if both 1st BEM of primary and secondary rack fail will the second BEM of primary and secondary rack take over Genius communication?
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
393
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
288
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
109
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
981
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
396
