S300 -Could the project create Bus Failures?
eddy2016
Nov 2016
The Hague
Hi all, I'm quite new to this. Although I have some IT knowledge this is different stuff. I'm breaking my head over the following. I have SF and BF failures on the CPU. Checked all Profibus wiring A-B, FC connectors, addresses etc. which seems to be OK. I have uploaded a project via S7 Simatic.(MPI) So I can communicate but can't see all slaves due to BF failures. Now my question could the project influence Profibus and create Bus Failures?? If so how could I go back? Just delete all blocks of the project?
I don't think my question was that difficult. Maybe I should rephrase. Q. Do you need to download a project to get profibus working so that no BF alarms will appear??
Yes you need to save compile and download the hardware configuration!
All nodes that you have configured must then be powered up and match the HW config in order for the BF light to go out.
The CPU does not magically know the slave nodes that you have connected you need to add them into the HW config in order for the CPU to recognize them.
Check your terminator switches on the Profi-bus cable as well
note the IN - OUT cable points
Hi I need to setup a Delta MS300 VSD. I have not done something like this in years so any help would be appreciated. I am going through the...
1,293
Can anyone simplify this code for conversion into Studio 5000 LAD. Thanks
1,389
hi all, I am new to this page but work in the automotive trade as electrical mechanical maintenance engineer just done a basic plc course with...
1,109
I'm trying to find out whether it's possible to interface an InTouch SCADA system to a CS300 system using the CS300 peer-to-peer protocol. Any...
1,948
Hello,I have simatic s300 cpu314 with FLASH card (6e7 951-0KE00-0AA0) and sometimes PLC go to stop mode without apparent reason.I want to change...
2,786
