S5-115 problem
michaelchan
Jun 2007
FUJIAN PROVINCE
43
Hi all,I have S5-115u 943B processor,there is no output when running the processor,run led is on,using Step 5 to connect the cpu to view the info of ISTACK,find Items BATPUF,AF&KEINAS mark [font=&#23435]×,what does it mean?Could someone know it?[/font]
[font=&#23435][/font]
[font=&#23435]P.S I really know little about S5.[/font]
If the RUN LED is on and outputs that should be on are not on can only be one of three things:
- logic to activate outputs is not active, waiting for some condition
- no power to input/output cards
- PLC has lost program
If the PLC is running you cannot open the ISTACK, the ISTACK is only available when the PLC faults.
EDIT: Sorry, the second page is only available when the PLC has stopped in fault. The first page info I had never used in 15-20 years of working with S5.
Hi.. I have one problem with siemens S5 115u cpu 942B. In that cpu, EPROM module of 32kb is installed. Now, i changed one segment in the program...
4,092
hello everyone, i have problem with communicate between siemens op25 and s5 115u cpu941b. when i upgrading the timer or anything else by using...
1,313
hi the problem is that everything is ok while we connect to plc and we can see the program pb,fb,ob,sb,db in the plc while online but when we...
5,188
hello i am a newbie to s5 and i have the following problem in a plant here. the s5 crashed at general power failure when the power came back on...
5,817
How to fix if appears code “$115 plc-restart running” on the screen OP17
253
