S5 944B CPU problems
douglail
Oct 2006
nc
i have this CPU, and i can't communicate with it. there seems to be something wrong with the unit, because the LED configuration is something i've never seen before.
when i power it up, all the LEDs flash, then they ALL go out except the BA light. there is neither a RUN nor a STOP light lit, and i've never seen that before. RESET has no effect. (doesn't look like it tries to reset at all actually, no changes in the lights)
any ideas what is wrong with this CPU? it's one with a Flash Expantion OS module in it.
You said the reset does not work...but have you tried a overall reset? I'm not sure on the 944B, does it have two switches on it? and do you have a GOOD copy of the program?
yeah, tried overall reset, and the stop light flickers once. then nothing. manual says that it's "checking program memory" when run and stop leds are both out, and that a flash after overall reset indicates a memory selftest error.
good program or bad, doesn't matter, i can't communicate to it at all. gives a 'plc timeout' in the software.
i'm proceeding on the assumption that there's a problem with the memory. we've got a replacement isntalled already and we're repairing the bad CPU.
Thanks for the advice. among other things here, we do board level industrial electronics repair. we've fixed quite a few S5s, but havn't seen this type of error before, and i needed a few ideas about where to look for the failure in the unit.
hey everyone i have problem with my cpu, the cpu goes to error and i check ISTACK some data error but i'am not understand about listing program...
1,339
:furi:plc cpu trip many time indicat 3ledlight red color flows how solve problem
1,677
Hi all, Just wondered if anyone knows how much memory is in a S5 115U CPU 944B ? I'm spec'ing an S7 PLC and wondered about what size MMC card...
3,162
Hello, The thing is that I don't have to much experience with siemens and I have a problem, I think the problem is the CPU, because all the red...
4,188
Currently, our Siemens S5 PLC (model 944B)uses an EPROM with part# 6ES5 375-1LA61. Works great... but, I'd like to instead use an EPROM part# 6ES5...
3,170
