What EPROM can be used: S5 944B
edward4444
May 2006
New Hampshire
Currently, our Siemens S5 PLC (model 944B)uses an EPROM with part# 6ES5 375-1LA61.
Works great... but, I'd like to instead use an EPROM part# 6ES5 375-0LA71.
I burnt the "0LA71" EPROM... no problems there... but it will not run in the PLC.
Question: How do I make the "0LA71" EPROM work in the 944B, or, is there some fundamental incompatibility that prevents me from using this EPROM in the 944B card?? Thanks much
it should be possible to use this eprom, but you have
to set the operating mode within the prommer to WORD or WORD/BLOCK instead of BYTE.
2.) The maximum size for programm is 96K , even the
sizeof eprom is 128K!
Look here
regards
Rolf
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
123
Hi , we try to get a CPU 317T-2 D back to life,memory card was defective and with some resets we have only sf light red flickering we...
28
745
I have a Siemens S7-200 with a bad output. Bought a new processor, PN 6ES7 214-1AD23-0Xb0, to replace it. I have an EPROM Memory Module, PN 6ES7...
813
Hello, I have a one off job to modify some Siemens Step5 software at a local factory. The PLCs are S5-100U (CPU103). I have uploaded the PLC code...
4,311
Dear All, I have an S7 300 damaged CPU. I don't have it's backup program. I want install a new CPU. If I replace the new CPU internal EPROM with...
1,686
