Siemens CPU 224 Program Transfer from EPROM
Rockfordmfg
Feb 2013
Tennessee
74
I have a Siemens S7-200 with a bad output. Bought a new processor, PN 6ES7 214-1AD23-0Xb0, to replace it. I have an EPROM Memory Module, PN 6ES7 291-8GE20-0XA0 from the OEM that has the program on it. Have used it in the past and it seemed to work.
Now when I put this into my new processor I get a "TD 200 RELEASE 2.1.0 NO PARAMETER BLOCK" message on the TD 200 HMI.
The processor will not switch into Run mode with the EPROM installed. If the EPROM is removed and the battery is installed the unit will switch into Run mode but it is not actually working. No outputs and the "TD 200 RELEASE 2.1.0 NO PARAMETER BLOCK"
We don't have any Siemens programming software, only the EPROM modules. Any thoughts on this?
..and don't use the integrated I/O so if/when it fails you don't have to replace the CPU for the sake of a bad output.
Hello All, I am using siemens s7 200, CPU 224N. The problem is PLC has program but when i am uploading it, everything goes successful but the...
4,038
Hi; I have a Siemens CPU 224 (6ES7 214-1AD23-0XB0) with a password protected program installed. I want to ask that how can I break the password...
3,055
I have a Siemens CPU 224 controlling a Sullair Air Dryer. I will like to connect to this PLC using my AutomationDirect PLC06 using the Modbus...
4,762
How long does the 224 hold its memory. I guess I could look on Siemens web site, but I don't have 3 days to spare. I guessing it's slightly...
2,600
Hey when I turn on my Siemens PLC CPU 216-2 after runing 10 minute it's stop and showing SF indication after I turn off and some time later turn...
120
