S5-95u analog module
wbaldisser
Apr 2008
Montevideo
I would like to know if it is possible to read from an analog sensor 0-5 V with an analog module input of a s5-95u. I sow in the manual that this plc module only read 0-10 V.
I want to say that I'm not an PLC's expert, that's why I'm asking.
In case that is possible, where I have to set so I can have a correct reading.
Thanks.
PD: Sorry for my English :(
In the 95U there are analog processing blocks (FB25x ) these blocks are in the range 250 to 255 anyway, the one you want is RLG-AA or EA I think.
The blocks are stored in the plc so you can upload them into you project before you start.
Call the block then parameterise it as required however as you are using 0-5v you are only using part of the span.
The function block requires a number of parameters these are the analog address, type of input, upper & lower conversion (zero/span of converted value), error flags & fw/dw you want to store the value into.
I cannot find my old 95 manual but the information is in there somewhere.
I'm sure someone here can remember that far back.
I m new in STEP 5 and i need help I have problem with the onboard's analog output 4-20mA, i want to forced it to see if it work or not but i...
1,984
I have the above CPU. I need to check if the onboard I/O are working. I am viewing it on line with Step 5. I have a manual for it, it has eight AI...
4,407
I have a system with this PLC and there are 8 analog input devices connected to the onboard A/I terminals. In the program, I can only find PW40...
2,928
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
236
Hi All, We have a hydraulic press that is being controlled by Siemens S5-95U PLC . Lately the S5-95U has been randomly stopping during operation...
2,420
