Siemens S5-95U Onboard Analog
bluenoser337
Apr 2003
Nova Scotia
391
I have a system with this PLC and there are 8 analog input devices connected to the onboard A/I terminals. In the program, I can only find PW40 and PW48. I should be able to find them all from 40 to 54. What could I be missing? Thanks!
The Inputs may be indirectly addressed. Try searching for PW0.
The code may look like:
Code:
L KF +40
T FW 200         FW200 Contains 40
DO FW 200
L PW0            Will Load PW 40
Nick
Thanks Mangle...No luck with that search. I can find all the analog input code (I think). Some appear to be for cards that don't exist? Example: BG KF8, KNKT 1,4. If some analog were only there for HMI display, is it possible that they wouldn't have code and the HMI may address them directly with PW42, etc?
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
237
the steps to have a backup from the plc siemens Simatic s5 95u?
2,404
Hello, Dear Friends.I have an Simatic S5-95U PLC,How to upload program from this?. i have PC to TTY cable also and step 5 software too. please...
4,608
Hi, Dear Friends. I have one Siemens S5-95U PLC with EPROM installed in it, i am unable to upload program from the PLC although i have STEP5...
6,226
Hi, I have a machine with a S5-95U plc......with a problem. Last week we had a fault in an inverter unit, which melted some cables in the panel...
2,229
