S5 endless loop
stevedunk
Apr 2006
FNQ
52
We have a 135U with 928b cpu controlling a 9 MW condensing turbine.
I am in the process of working out what is happening with various problems with the machine/program. We are having the documentation translated and I have(expecting delivery)copy of bergers 135u book
I am using S5 for windows and when i use the simulator to run the program an error message pops up telling me that "Block FB 196 may have an endless loop" and am unable to progress further.
the block in questions code: NAME : Stop
ANF : STP
JU =ANF
BE
It does look like an endless loop and is called by OB's 21 22.
The program runs on thge real PLC but appears a little glichy.
I'd be interested on comments on how the start and reset OB's use this FB 196 .
My suggestion is that the only type of restart that is allowed for your system is a cold restart (OB20). If a warm restart is attempted, FB196 gets called and goes into the endless loop preventing any further processing from taking place.
Hello, CX9020 gets stuck after about two seconds after booting. Mouse pointer stops, won't allow access through system manager (timeouts) or web...
5,485
In my recent "whaddafuh" post, I got alot of good suggestions, and some criticism on shotgunning the repair. No arguement, I don't like...
4,157
Trying to identify the cause of cycle time overruns causing the CPU to go into STOP (see SFC12 Thread here I eventually tracked the problem down...
5,573
Hello, Before I make my inquiry, allow me to introduce the setting of my question... I am doing a senior project with PLC for college. I am also...
21
11,118
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
379
