S5 Plc and KTP panel connection.
tulip
Oct 2005
ist
236
Our a customer has got S5-95U Plc and OP17 Hmi.OP17 is defect.They want to use a new generation Siemens Simatic basic panel (KTP400,700,1200 etc.).
And we know that this panel and plc have different communication protocols.
My question is; Is there any converter for these two systems to communicate? If yes, what is the order number?
Thanks in advance...
S5 is long gone, looking at the data sheet for the HMI it will not support the S5 connection & does not appear to be a current loop (232) port.
I suggest you either get a re-furbished one or better still replace PLC & HMI. you are going to need TIA anyway to program the HMI
:yakyak: :bow: Reported Issue : Siemens HMI does not Communicate with Siemens1200 PLC. Sequence Of Events : Checked status of HMI and PLC and...
5,456
Hello People, I need your expertise of Communication problem. I am having a KTP1000 DP and ABB PLC which I need to communicate. Now ABB wants...
3,685
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
49
Hello all. I recently had to re install my AutoCAD Electrical 2024. I am trying to find the Rockwell catalog to install in it but cant find...
79
47
