S5 siemens module ET 200 imput signal
okke
Apr 2010
Miercurea ciuc
Hello, i have proble with S5 imput signals, when the plc is in stop mode the signal on imput is ok(on program online),when plc is run mode the imput switch to 0, even if the 24v imput voltage is OK, the led of imput LED light.Cant find the problem HELP!!! Thank you
hi guys! can anyone help me in using analog module! i dnt know the input addresses! can anyone quote a ladder program
6,714
Dear friends, Presently we are commissioning S7-200 CPU 226 based machine in our soap plant. The configuration is CPU 226 + EM235 + EM232 + EM...
7,795
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
124
Hi! Doing a lab project with two 1214FC. Got a warning about reintegration of modules wasn´t configured and tried to do that. Found the two...
808
I have a 6ES7 421-7DH00-0AB0 card with the INTF LED illuminated red. This internal fault on the card is preventing the CPU from going into run...
1,122
