S5 software version
cck
Jun 2003
My company is using Siemens S5 PLC, Cpu 945 and 948, currently we
are using PG730, but I would like to change it into laptop window
base S5. Anyone can recommend what version of S5 most suitable..
cck
cck
What version of Step5 have you currently got installed?
Step5 runs in a DOS window under Windoze OS, as far as I am aware no version of Step5 runs in windoze, I am currently using Step5 V7.1, running on a Windoze 98 machine. You should be able to upgrade fairly cheaply if it is indeed the case that the version of Step5 you have will only run under DOS.
Paul
I have downloaded a demo version of PG2000 from "process informatik"
to my compaq notebook, i tried to go online with Siemens PLC s5 115,
CPU 945 using Siemens cable 6ES5-734-2XXX0, I plug the 25 pin into com2(printer port) and try "online" but failed, can anyone know about this software and how to do the communication? My question :
Are the software only for use in PG?
You should go online with a cable from your com1 (9pins), so you need a rs485 - rs232 converter, see on the same site for this. You can purchase this everywhere.
Regards
C
My PLC (S7-1200 with CPU-1212C) has now been delivered to customer site. They've asked me to do some updates to the software. I can do that on my...
21
461
Does anyone know where I can get TouchWin Edit software version V2.C.5 or above? Xinje's website is lacking. I just got a newer TH765-N display...
172
My comptuer is 64 bit OS and Install studio5000 versio 30. my question is can I install version 19 software on it? Anyone have run version 19 on...
2,675
My memory is failing me. I seems to remember I could download which ever version of any Rockwell Automation software as long as they are covered...
2,511
Hello everyone, Is there a free version of Rockwell's programming software for Allen Bradley plc's? It's been a lot of years since I worked with...
5,033
