S7-1200 FB/FC for profinet device
Ghoetic
Mar 2012
hemlijaure
Hey.
I have an S7-1200 system, which i intend to communicate with a eurotherm Epack 1ph controller via profinet.
I have installed the GSD and added the telegram modules.
Now i would like to get some input/tips/best practices for working with the device as a seperate block.
Meaning i want to make a FC or FB and be able to set remote setpoint, firing enable and then read Voltage,current, PV,SP.
Should i tag the inputs in a tag table and use these on the outputs or is there a way to have input to the FC/FB for the input/output adress. lets say inputs start at 112
Made a mockup of the examples.
And just for the record i am a very much new to the siemens ways of programming
Create PLC data types for the drive inputs and outputs and use those data types in your tag table and parameters in your FB
Thank you.
Sorry if im pestering, but could you show the complete picture how it's used.
In the FB editor i set "Epack_inputs" with type Epack-1PH_inputs as defined.
This gives me one leg on the left side of the FB when used in OB1.
No idea how to use it.
Any references would be nice.
Create a tag for your inputs at the inputs address given the h/w config.
Enter the tag for the input parameter to the FB.
Hello S7 experts, here you are perhaps the dumbest S7-1200 question of the year, but I will be so grateful for some expert advice after you get...
2,602
Hi all.. I'm working on something that is bugging the heck out of me. I have a S7-1200 setup as an i-device with 128 bytes in, 128 bytes out...
7,216
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,937
Hello All I have a modbus tcp device(Julabo magio) with an DB9 pin assignment. Pin3=B and Pin8=A. I would like to connect it on the secondary...
1,630
Hello all, I'm working with an s7-1200 and a stepper motor in Tia portal v17. This stepper motor is an SMD23E2 and I am attempting to connect...
19
2,870
