S7-1200 High Speed Counter w/ Shaft Encoder
I had Siemens tech come out to site and take a look and he does not know why it is not working either. He is doing research and will get back to me. I'll update when we figure it out.
Don't know why I didn't remember this, must have been having a thick day or two.
Have you reduced the input filter values, they come set way to high to use inputs as High Speed. Double click on the PLC, go down to Digital Inputs, Input Filters, set that down low enough to match your maximum pulse input rate.
Also don't forget to add the :p as given in my first post, otherwise you get an out of date value of pulse count.
Boom. That did it. I appreciate everyone's input and advice!
Jason
I have a current project replacing S7-200 PLC with S7-1200 PLC (6ES7 215-1AG40-0XB0). The program conversions are manually created. I just want...
1,739
Looking for example of the use of the HSC in a CPU 1212C PLC. Not sure of how to establish Hardware ID, and which input to use the ID1000 is it...
1,822
Hello everyone, I got a question about the High speed counter It needs to move out a slide when the count reaches 100pules, and it needs to move...
4,108
I have a 1762-L24BWA microligix 1200 that gets an input from a proximity switch that is mounted near sprocket the prox picks up once per...
5,038
I am having an issue with either the Encoder – an Encoder Products 25T-40SG-0500NV1RPP-SMJ-S3 or the High Speed Counter on a ML 1200. The encoder...
4,549
