S7-1200 hour counter?
rQx
Oct 2010
Trelleborg
1,051
Hi!
Even in the simple Siemens LOGO there was a hour counter, counting the time an, for example, input has been set. Where is this in S7-1200. I've checked the manual and searched the Help but no luck. Do I have to build my own? :/
I do believe so.
If the CPU has an RTC (Real Time Clock) you may be able
to use it instead.
I don't have the S7-1200 software here.
Need help a source code to make timer display into hour:min descending from a time of delay 1 sec base timer. Thanks
22
5,922
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
133
